Hi all.
I have a Michell GyroSE with Technoarm fitted.
Up to these days I was using a Grado Reference Sonata with 1,5 gram VTF and worked fine.
A few days ago I changed the cartridge to a Denon DL-304 which uses a downforce of only 1.2 grams.
But I have noticed that bias adjustment (anti-skating force) is not working well. If the arm is at rest, then when moving it on the beginning of the record and all the way to the last track, it behaves like it has a lot of anti-skating force applied, (no matter how bias setting is, even at 0) causing the needle to stick to some points, or in other words truing to move the arm backwards.
But, if prior to listening, from arm rest I get the arm, move it by hand up and beyond the platter spindle and return it for playback, antiskate force is not applied and the cartridge plays fine in the grooves. This strange behavior is always happening and I must always, prior to listening, first move the arm above the record to the spindle and then back in the beginning of the record, otherwise a LOT of anti-skate force is applied even with 0 (zero) bias setting.
The only change from before cartridge replacement is a change on the tonearm cable position, from the back of the Gyro to the right side of it.
I have read that anti-skate force on the Technoarm is magnetically applied.
Is there something wrong with the magnets, and basically, something that you can advise me to do on it;
Thank's.
Thank's.
