Strange MCE screen shift behaviour
Discussion in 'Microsoft Windows' started by OneEleven, Jul 28, 2005.
  1. OneEleven
    OneEleven
    I've built myself a MCE machine based around the mediaPC.tv slimline intel bundle (which is fantastic by the way) :thumbsup:
    I'm running PowerDVD6 codec and have backuped up some of my DVD's using Divx (simpleDivx front end).
    Now when I go into MCE and play a DVD or a Divx file the display compresses leaving a black band down teh left hand of the screen (42inch Panasonic plasma) - almost as if it's 1/2 displaying in 4:3. Exit from watching a move and the band is still there. :thumbsdow
    If I exit MCE back to the OS then there appears to be a resolution change (screen says no signal briefly) and then the desktop appears across all of the display; go back into MCE and the band re-appears. :confused:
    Play Divx or DVD outside of MCE then they fill the complete screen so I doubt it's an encoding/decoding issue.
    I was messing around with powerstrip (now uninstalled) before this problem manifested, could it be that? :confused:
    I don't really want to do a new install :nono:
    Anyone any ideas :lease:
  2. Skunkpipe
    Skunkpipe
    Have you been changing the refresh rate in the screen settings->advanced->Displays->monitor tab ?
  3. lisag
    lisag
    Jul 14, 2004
    5,669
    Essex
    +330
  4. OneEleven
    OneEleven
    Sorted - thanks. the refresh rate was set to 85Hz in the advanced bit where you said, and 60Hz in the normal settings - changed the 85 to 60 and whey-hey; all is good
    :smashin:
  5. nigelbb
    nigelbb
    Apr 4, 2005
    5,261
    103
    +488
    Have you got a pointer for this? I'm just about to emabark on building a new MCE machine & would like to get a really nice one this time.
  6. OneEleven
    OneEleven
    sure; it's www.mediapc.tv
  7. nigelbb
    nigelbb
    Apr 4, 2005
    5,261
    103
    +488
    Thanks. Looks like they have some nice stuff. The web site is a bit of a mess though in both IE & Firefox. Half the time the images don't download & every so often it asks me to log when I am just browsing through the store.
  8. Skunkpipe
    Skunkpipe
    nigelbb; that's our site, can you PM me with the issues you're having please.
    I'm not having any issues from IE and I've just had a firefox user (Mac based) give it the once over with no issues
