Quantcast
Strange marks on wall
tigermad
Just came across these 2 small patches on the spare room walls. They are internal walls and were painted just before Christmas. I have tried wiping them off but it does nothing? They have only appeared the last week or so and we hardly go in there.
Any ideas what has caused them or should I just try and paint over them.
has2mow
Before you try to cover them again with emulsion, coat the dots with an oil base paint, that will stop them bleeding through again.
IronGiant
Raise whatever it is sat in the corner by 15cm :D
danmc_82
Looks like a sad corner :(
Similar threads
