Strange Linn Karik display behaviour
Discussion in 'Hi-Fi Stereo Systems & Separates' started by chedmaster, Jul 9, 2005.
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    Just been sorting out my Dad's stereo system, he has a Linn Karik/LK180/280/Keilidh system, and recently the display has been playing up on the Karik.
    It comes on fine, plays fine, and the display reads Track 1 Index 1 etc. Then you skip tracks etc, for example Track 5 Index 1 (never use Index thing) and after about 10-25 seconds, the display cuts to - - . Sound keeps playing fine, and sometimes it automatically goes back to proper display, and always if you press a button, but the timing seems random. :confused:
    Anyone have experience with them and can help?
    On another note, man am I jealous of his system!!! :rotfl:
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Same as on the CD12. The display can be set to either display timing or the 2 slightly evil looking slits. Usually display stays up for 20 seconds and then reverts to the slits.
    Can be set manually on the CD12 not sure about the Karik but it is normal....
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    theres a button on the back that says "display" i assumed it turned it off but it doesnt, maybe thats it. it never used to do it. thanks for your reply
  4. suzywong
    suzywong
    Nov 6, 2003
    261
    19
    Southampton
    The thinking some years ago was that strobed LED displays had a detrimental effect upon the sound, caused by the fast edge speeds of digital signals breaking through to the audio path. A classic EMC problem. So there was a move in high end audio circles, such as Linn, towards having the ability to switch the display off. This could be either manual or automatic depending upon the design of the digital circuits.
    So be not afraid, this sounds completely normal for a Karik (mine does the same thing - currently playing very nicely, thank you,and showing "--").
    on the other hand you are right to be jealous of your Dad's system...on the lines of "cower down before my Linn Karik/Numerik/Kudos/Kairn/Aktiv-Dirak-Bingo/LK280*3/PMS Isobariks, ye Mortals!" :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl:
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    lol i keep telling him to get a numerik!
  6. suzywong
    suzywong
    Nov 6, 2003
    261
    19
    Southampton
    the Karik is a fine player in its own right, the Numerik makes it better; I've played around with both Karik-on-its-own & Karik-Numerik in my system, and also with and without the clock synchronisation cable between the K & the N. each time I've added more bits in (i.e. Karik, Karik + Numerik, Karik + Numerik + sync cable) there has been change (and, I like to think, an improvement in sound quality).
    However......tell him to go aktiv.....
    then you'll really hear something!
  7. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Have a heart Suzywong, 2 weeks ago I returned home to find my CD12, Klimax Kontrol, Klimax Twins, Akurate 242's and several other Amps and cables had been stolen.:mad::mad::mad::mad::mad::mad:
    And i'm still waiting for the loss adjusters answer....:suicide:
  8. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    Sorry to hear that Knightshade, you must be gutted! Especially as you can't buy a new CD12 anymore...
    Hope you get a sensible answer from your loss adjusters, and then the fun of testing out some new kit. Artikulats and Chakra amps all round, anyone?
