Strange Colour distortions
Discussion in 'Home Cinema Buying & Building' started by dmort25, Jan 2, 2005.
  1. dmort25
    dmort25
    Hello,
    I've just bought a JVC THS8 all-in-one system. Everything works great apart from a strange colour distortion which appears occansionally. My initial guess was that the speakers were too close to the t.v. but the disortion only really happens every now and again. I get a greenish blob in two areas of the screen, which comes and goes.
    Do you think that it could be the speakers (they are meant to be shielded), and why would the problem only manifest itself occasionally. Could this be a speaker problem, or should I accept defeat and move the speakers further away.
    If it is the centre speaker can anything be done to reduce the distortion as the speaker has to sit above the t.v.)
    Thanks in advance,
    Dave
