Strange coating on DVD's
Discussion in 'Movie Forum' started by skimber, Feb 21, 2002.
  1. skimber
    skimber
    Dec 1, 2001
    205
    19
    I am have a problem with most of the DVD's i have bought from play.com. They see to be sealed in some kind of invisible force field that prevents me from opening the case.
    I have tried to ask play for a refund but they just said "Remove the plastic bonehead!"
    Where do i find this "Plastic Bonehead" and do i need any special tools to remove it?
  2. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    Same problem here. Let me know the trick when you've figured it out :cool:
  3. skimber
    skimber
    Dec 1, 2001
    205
    19
    will do!
