Strange buzzing noise
Discussion in 'TVs' started by thelord, Jul 19, 2004.
  1. thelord
    thelord
    Jun 10, 2004
    12
    I recently took delivery of the Sony KV36HQ100S.
    I have only had the Tele for about a month and its started to make a buzzing noise from the back of the unit. Normally I can't notice as I have it loud but late at night when my wife has gone to bed the volume is much lower it is then I have noticed this buzzing noise.
    It makes the noise whether the tele is muted or not and I have tried DVD a Cable box and normal terestial it makes no difference.
    Do I need to call Empire-Direct and get someone to look at it or is there a fix I can do at home?
    Your help is going to be invaluable.
  2. Zaichik
    Zaichik
    Mar 5, 2002
    1,251
    +279
    I think most sets buzz to a certain extent. My new Panny does, and my old Hitachi did. The impression I get is that 100 Hz sets are more prone to it than 50 Hz. It shouldn't be audible at normal viewing volume.
  3. Uzey
    Uzey
    Tele = Telly?
  4. thelord
    thelord
    Jun 10, 2004
    12
    Silly me Telly, I work for ntl and I am so used to using the word te :oops: le
  5. Jack Bowyer
    Jack Bowyer
    If the noise (buzz) is from the back of the set (around the neck of the tube) then it will be the scan coils I would guess.
    Put your ear to the top towards the back and see what you can hear.
    If its noise from the speaker then I would guess its power supply related.
    What Sony will do about this is anyones guess - maybe a mod kit of some kind if its scan coils
    Contact empire asap....and pray they dont send some sub-contract cowboy engineer out to you.
