Strange....but here goes...
Discussion in 'PC Gaming & Rigs' started by Paul-r1, Jul 30, 2003.
  1. Paul-r1
    Paul-r1
    May 23, 2003
    102
    Bognor Regis
    I have a 21" Industrial monitor (Don't Ask) which has 2 standard PC input sockets on the rear, and a handy little switch on the front to toggle between the inputs. What I would like to do is plug my PS2 into the 2nd socket (PC is in the 1st socket), thus allowing me to use the monitor for my console gaming.
    Does anyone know of a company that sells the required socket adapter to allow me to do this? Just a normal female 3 pin to (whatever the standard sockets are called) socket.
    Or am I barking up completly the wrong tree and should invest in a card for my PC to enable me to play the PS2 that way? God I hope not.
    ANyhow, thanks for any info you guys can give me.
  2. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,681
    aka Billy Science - Suni ojna Tas
    +430
    From a quick look around heres a link to a product that will do it for you - not sure if there are better or cheaper products about.
    PS2 vga box
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
