Strange Beeping noise being output from AV amp ??
Discussion in 'AV Receivers & Amplifiers' started by Ciqala, Aug 18, 2005.
  1. Ciqala
    Ciqala
    I have a denon av1905 (full kit list in sig) and tonight i noticed it's making a very high pitched beeping noise.
    i've tried all types of output stereo, 5ch stereo, DD, DTS etc across all the various inputs and it always make this noise, i even get it when i use headphones. it sounds like a feint alarm going off in the distance and is just the right sound to give you a pounding headache in a minute or two.
    i'm at a total loss as to what may be causing it, any suggestions on the first things i should try and rule out?
    thanks in advance.
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,493
    Birmingham
    +205
    try unplugging all inputs and see if the problem goes, then plug everything in one at a time. I would imagine your amp is picking interference up from somewhere.
  3. Ciqala
    Ciqala
    shall try it tonight, thanks.
