STR-VA333 upgrade
Discussion in 'AV Receivers & Amplifiers' started by stef63, Feb 10, 2003.
  1. stef63
    stef63
    Dear all,
    I'm a french owner of a receiver SONY STR-VA333es.
    I upgrade this product with the new firmware v1.18.
    My questionh to others owners :
    Do you have the indication of the version of the firmware when you rotate the jog because for me it only indicate STR-VA333 ?
  2. Heimnes
    Heimnes
    Hi there!
    I recently bought the VA333, and the other day I also tried to find the software version through rotating the jog - without luck...
    Supposedly, you can get the VA555 to show this info; does anybody know how this is achieved on the VA333?
    Ta!
  3. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I don't think it can be displayed on the 333, although the firmware upgrade utility might tell you the version you have...
