Answered STR-DH820 surround or height
Discussion in 'AV Receivers & Amplifiers' started by CornishPete, May 30, 2018.
  1. CornishPete
    CornishPete
    Jan 27, 2016
    40
    10
    11
    12
    uk
    +24
    Ok so I have a Sony STR-DH820 and a Panasonic EX750B with a Panasonic UB400 blu ray. Unfortunately I can't afford to replace my current 7.1 for an atmos AV. So my question is do I just stick with the 4 rear surrounds I have or do I try having 2 front heights (dolby z) will it help with the atmospherics? Or am I better to leave it.
    Thanks in advance
    Pete
  2. Best Answer:
    Post #2 by dante01, May 30, 2018 (1 points)
  3. dante01
    dante01
    Mar 5, 2009
    45,205
    +10,633
    Best Answer
    I'd suggest you stick with the back surrunds rather than sacrificing them for front heights. You'd only be able to utilise the heights in conjunction with upmixing modes that create pseudo channels for them with your receiver, but back speakers will portray discrete audio if playing 7.1 sources. I'd maybe sacrifice them in order to get Atmos, but I'd not rate Pro Logic iiz as being worth the sacrifice.
  4. CornishPete
    CornishPete
    Jan 27, 2016
    40
    10
    11
    12
    uk
    +24
    Fantastic thanks for the reply. I will have to save my pennies and get the STRDN1080
