STR DH800 for music?
Michael1981
Ive got a DH800 for my surround sound with some harmon kardon speakers. With this set up give me good sound for music too? Do I need to but a seperate piece of hard ware for my music or can I link up my laptop to play mp3? I tryed linking my laptop up via HDMI in HDMI port2 on my amp but I cant get and sound through. Anyone any ideas what to do? Thanks.
mattlow93
you'll need to buy a phono to 3.5mm jack,
an example (though I wouldn't buy from Maplin! It's worth paying about £10 and getting one that won't fall to bits. The wires in cheap audio cables can disintigrate after being flexed.)
Plug into the CD input on the receiver (or similar), and mess around with the settings so that you can get sound from the cable through all speakers, not just the front two.
Hope this helps
Michael1981
Does this mean I can use my laptop as a player? Why cant I get sound by using my HDMI lead? I did it one when I first bought the amp by mistake and havnt been able to do it ever since.
davepuma
It depends on the specs of the graphics card (GPU). HDMI on PC's is relatively new and not all HDMI equipped graphics cards support audio output. The PC forums are your best bet. Make sure you post as much information as you can as remember not all PC's are the same.
dante01
I'd not rate the STRDH800 as being a particularly musical amp and the HK speakers are not the best you can use in conjunction with it. The Sony amps have a clinical nature and can be regarded as being bright, especially if used to power clinical speakers. The HK speakers are clinical and will give rise to sibilance if used with a clinical amp such as the STRDH800.
It may be that your computer's HDMI interface soes not have the ability to stream audio? Try a different audio interface between your PC and the receiver.
