STR-DB795 Impedance
Discussion in 'Home Cinema Speakers' started by gna03633, Feb 25, 2005.
  1. gna03633
    gna03633
    Hi All
    My Kit
    Sony STR-DB795 with A+B
    Mordaunt Short Genies
    I have the impedance set on the receiver to 4ohms based on the Genies being rated 4-8ohms and this info from the manual (However, be sure to set the IMPEDANCE SELECTOR to 4 if you connect one speaker with a nominal impedance between 4 and 8ohm).
    I wanted to connect a set of speakers onto the B output, which I would use in the bathroom. Can I connect speakers with 8ohms, or must it be 4ohms?
    thanks
