Stowaway Screen
Discussion in 'Projectors, Screens & Video Processors' started by Andyclockwise, Apr 6, 2003.
  1. Andyclockwise
    Andyclockwise
    Apr 6, 2003
    129
    Leicester
    +13
    Can anyone recommend a good value 150cm pull-up floorscreen for home cinema use that can be stowed away and transported easily.
    I have looked at various pull-up floorscreens on the internet and am now confused.
    What type of material should I consider - is it worth paying an extra £75 or so for high gain 1.5?
    Also where is a good place to buy from - cost and service reliability being the key considerations?
