StormAudio PA 14.200 Amp Experience
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by MoneyInABlkHole, May 4, 2016.
  1. MoneyInABlkHole
    MoneyInABlkHole
    May 4, 2016
    5
    Santa Clara
    Hello everyone. I have been out of this game for awhile but back in it with a vengeance (translated as $ burning a hole in my pocket). I am upgrading my system to a 3D audio experience and need some feedback on amp experience. I am looking for a multi-channel amp that supports global power, i.e. 100v-240v. I live in Japan but may relocate back to the states in a year. So I need the flexibility. Don't want to wait a year to hear my music/movies!
    Has anyone heard or owned one of the amps from StormAudio? The PA 14.200 or PA 8.200 are both in my sights but pubic data is scarce, which makes me a little nervous.
    Thanks for the input.
  2. sammy the squid
    sammy the squid
    Jul 5, 2009
    8,841
    Lancs
    +3,492
    If you're back with vengeance you may want to try a different amp manufacturer. I'm pretty sure Storm Audio were bought by Auro 3D. The processors may still be available but I honestly have no idea what the fate of the amps was.
  3. MoneyInABlkHole
    MoneyInABlkHole
    May 4, 2016
    5
    Santa Clara
    Thanks Sammy
  4. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,507
    Bearsted Kent
    +1,920
    A number of amps and AVRs now support auto sensing of voltage from 110v to 240v IIRC
    I know the pre pro and 2 x power amps I have do indeed have this feature.
