Storing JPEGs and MPEGs
Discussion in 'Blu-ray & DVD Players & Recorders' started by arthurwatt, Aug 23, 2004.
  1. arthurwatt
    arthurwatt
    Oct 17, 2003
    40
    +4
    Good afternoon
    can anyone tell me if it is possible to record JPEG images onto a DVD? In the past I have burned my digital photgraphs onto a data CD on my PC. I would also use the DVD recorder for transferring my Camcorder footage onto DVD format.
    I have seen that some of the Panasonic DVD recorders have a memory stick input, so that might enable me to store the JPEGs onto DVD.
    I am also thinking about buying the Sony DSC-W1 digital camera, this can also store video (MPEG) on the memory stick, would it be possible to move the data onto a DVD (an alternative to using S-VIDEO).
    Thank you
    Arthur
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,869
    Warwick
    +2,785
    Assuming it is a digital camcorder then any machine with an iLink socket will be ideal (Panasonic E65, Toshiba DR1, Pioneer 320) although a HDD/DVDR machine would give you more options (Panasonic E95, Panasonic E500 or Toshiba RDXS32). If it's an analogue camcorder then any DVD recorder will do - although again a HDD/DVDR is more suited.
    The Panasonic E65, Panasonic E95 and Panasonic E500 allow you to transfer JPEGs from the SD or PC Card slot to DVD-RAM and they can be played back in slideshows etc. They cannot, however, be copied to DVD-R for playback on other DVD players.
    The support for video from portable devices on the Panasonic models is slim to say the least. The E500 allows MPEG4 recording/copying to DVD-RAM but almost certainly won't work with your Sony.
  3. Dr Downey
    Dr Downey
    Jan 12, 2004
    124
    19
    Cheltenham
    Most PC DVD authoring software will do Jpeg to DVD type stuff, obvioulsy you'd need a DVD burner in your PC for that, or if you do go for a recorder that has Ilink, then you should be able to transfer to DVD that way.
    321 studio's did a piece of software to make JPEG DVD's, don't know if that is really what you are looking for?
    Cheers!
