this is the part i am having trouble with "If your input source is MPEG based (.MPG, .TS, .M2TS, .M2V, etc), and you do not have compatible codec installed, you can use DGIndex to create a .D2V file which can be read by MEGUI. DGIndex is one of the Tools that is updated/downloaded automatically by MEGUI. You'll find it in the tools folder of your MEGUI install. Just drag/drop your MPEG file onto DGIndex, (see the GUIDES section for help with DGIndex) and save your project as a D2V file. For my Blue-Ray project, I will use DGIndex to extract the audio track from my .M2TS and to read the file since it creates a .D2V file for me. Note I could simply use the .M2TS file directly for video if I chose to since I have FFDShow and Haalie Media Splitter installed. "
just not sure how to make a d2v file , any help
