Stopping light scatter in a small room (projector)
Discussion in 'Home Cinema Buying & Building' started by Ducko88, Aug 25, 2018.
  1. Ducko88
    Ducko88
    Aug 24, 2018
    9
    Wales
    Morning folks,
    I decided to get a projector a week or so ago prior to that I painted my rather small room (10x11ft) magnolia which I now realize was a terrible choice as the room on bright scenes looks like I’ve switched the light on!
    What have people done to solve this issue?
    I’m debating doing the walls a dark Matt grey and the wall the screen is on / ceiling in black
    Will this alteration give a much better result or are there better ways to deal with this issue?
    Please see pics below (just to the right of the screen I also have a gloss white door.. far from ideal )
    Thanks!
  2. Ducko88
    Ducko88
    Aug 24, 2018
    9
    Wales
  3. razy60
    razy60
    Jan 13, 2008
    1,284
    83
    Eastbourne
    +322
    I painted my walls grey but couldn't paint the ceiling anything other than white due to creative differences, however a solution that seems to help is a black sheet as per the pics.
  4. Ducko88
    Ducko88
    Aug 24, 2018
    9
    Wales
    That looks good mate, did you find it much better after the grey and black cloth?
  5. razy60
    razy60
    Jan 13, 2008
    1,284
    83
    Eastbourne
    +322
    Yes, It does seem to help, I noticed that the contrast seemed to improve.
  6. Thug
    Thug
    Jul 17, 2003
    7,850
    3
    Middlesbrough
    +3,970
    Dark walls definitely make a difference.
    A dark ceiling would be better still, but I understand most of us cant do this.
    Here is mine...
    [​IMG]
    [​IMG]
  7. Ducko88
    Ducko88
    Aug 24, 2018
    9
    Wales
    Looks really good, what colour grey have you used? My spare room is dedicated to being a cinema/gaming room so I can do it any colour I want luckily I’m just trying to decide what colours to use on the ceiling and on the walls as I ideally don’t want it all the same colour
  8. Thug
    Thug
    Jul 17, 2003
    7,850
    3
    Middlesbrough
    +3,970
    The colour was called Denim Drift.
    Personally I would use all the same colour on the walls and ceiling as furnishings and pictures etc will break it all up.
  9. Ducko88
    Ducko88
    Aug 24, 2018
    9
    Wales
    Thanks a lot
