CypherReid
I have an 85 inch nano tv and your first update broke sound coming from external sources to always use 2 ch stereo when selecting direct which was annoying but I could move to AFD and then your next update broke that.
Now I have to manually select everything depending on the source. Useless.
What's worse is while you can disable auto updates you can't disable the annoying message.
Total disregard for your customers.
Back to Sony for me. Never buy another LG. Don't believe the hype.
