T
TURK TURKL3T0N
Does it make a difference if you stand your XBox 360 up or down. I heard that they are more likely to break if stood up, is this true?
Generally it's believe laid down is the best way to go with any console that doesn't click the disc into place.
My opinion is if you have the space to have it laid down thats the best way to go
