Stock NW-HD5 stock earbuds vs. Shure E2c - HUGE difference?
Discussion in 'Headphones, Earphones & Portable Music' started by recsnmisc, Jun 20, 2005.
  1. recsnmisc
    recsnmisc
    Jun 15, 2005
    188
    Portugal
    Sony NW-HD5 stock earbuds vs. Shure E2c - HUGE difference?
    ...well, will there be a clearly noticeable difference in sound quality? I'm thinking of getting the Shure E2c ones but I wont spend any more money right now if there wouldnt be a considerable improvement. I'm not an audiophile in any way but, will I be able to notice a clear difference? Could you try and quantify the sound quality gap betwen the two headphones? Is it worth spending the money?
    Are there any other similar in-ear isolating earphones you would recommend?
    Thanks you.
  2. lukey
    lukey
    the shures are good but quite expensive at a minimum of £55 from ebay. The sound quality is good and the build quality is fantastic, the cons are that they are a bit fiddly to put it and some people find it difficult to get the right fit. A lower budget option is to try the sony ex71 which are lighter although more fragile, give a greater bass response and can be picked up for about £20. Personally i dont think there is a good enough difference to justify the shure e2c because of the although on build quality it makes up for it.
    I think whatever in ear phones you get you will see a marked changed in the listening to the standard phonotopia type earphones from sony which i assume is the kind supplied with the hd models
  3. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    What utter ********, Lukey - since when are e2c's a "minimum of £55 from ebay"..?
    Shure E2c's for £28.25 on eBay
    Get them from the above vendor, wind130, and they should arrive within four days (mine did) and you shouldn't have to pay (I didn't) duty - he'll refund it if you do have to.
    I can't comment on how they compare with the Sony 'phones, but I can say how pleased I am with mine. Very efficient at blocking out noise; probably better for your ears as you can subsequently turn the volume down.
  4. lukey
    lukey
    Engaged you need to chill..whats with the hostile response....When I bought my E2c's a couple of months ago from Ebay the cheapest i could get them was for £55 (albeit from a UK seller)..me thinks you need some lessons in etiquette my friend :suicide:
    your link on ebay makes the cost £41 including delivery!! and not £28.25 :rolleyes:
  5. recsnmisc
    recsnmisc
    Jun 15, 2005
    188
    Portugal
    Do the shure e2c's come with the "standard" (bigger) 3.5 mm stereo plug or the "mini type" plug? Thanks.
  6. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    Sensitive soul, aren't we? Didn't mean to be hostile, just mildly sarcy; but methinks you need to do some research before making misleading posts.
    Fair point on the delivery charges, though - didn't go that far. I paid £39.50 for the 'phones, £4.95 delivery and £2.50 insurance back in March - guess that the seller is making up for the exchange rate by upping delivery charges?
    recsnmisc - 'standard' 3.5mm
