Stingray Boxset
Discussion in 'Movie Forum' started by Starburst, Apr 6, 2001.
  1. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Just purchased the dvd boxset of Stingray from Blackstar. However the first volume plays the copyright notice and the carlton logo then locks up. Volumes 2,3,4 and 5 all play without any problems.
    I've been sent a replacment boxset and it has exactly the same problems. Currently using a Proline 1000 as my R2 player having a dedicated Pana A310 for R1 discs.
    Anyone else having problems playing the discs
    using the Proline or anyother R2 machine?
  2. Confucius
    Confucius
    Feb 1, 2001
    2,151
    Oxford
    +132
    No probs on a Multiregion Tosh 100. (or a PS2)
    [ 15-04-2001: Message edited by: Confucius ]
  3. Guest
    The Proline players are not the most reliable.
    But it does appear to be a disc problem and Carlton are looking in to the problem, they may repress Volumes 1 and 3 as they are the ones that are playing up on a lot of players.
