Stills from camcorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mab25, Jul 17, 2003.
  1. mab25
    mab25
    How good are still photo's taken with the "still photo" option on a camcorder. The resolution on my camcorder is 800,000 pixels (400,000 effective pixels whatever that means).
    Are the photo's good enough to print out and look reasonable.
    I am going on holiday tomorrow, but don't have a camera.
    My options are to buy a couple of disposable cameras or use the video camera for the stills.
    Also what file format does the video camera save the files as and can they be opened with tools like Paint Shop Pro.
    Thanks,
    M
  2. Duncan Craig
    Duncan Craig
    Jun 1, 2003
    258
    The Grim North
    +17
    The quality of the pictures is totally different depending on the camera and how it records the image.
    Most should record a progressive still, which would look a lot clearer than a plain old grab from the moving video.
    Most camera will grab in a JPEG type format, but don't worry about that too much, whatever it is, it will open in any image editing Application.
    Also some video cameras claim to produce megapixel stills, but you'll really have to try it and see. If you have the videocamera, just try it now.
    To view the image, often the easiest way is just to drag it off disc onto your web browser, at that can handle most image formats.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    The stills from my TRV33 are pretty good but definately not up to a 5MP quality
  4. Oskins
    Oskins
    Most DV take pics in 640 x 480 mode.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    TRV33 is 1152 x 768 I think
  6. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    Buy a disposable camera, Your camcorder won't take decent enough pictures for standard 6X5 prints. You need a megapixel camcorder like the TVR33 for that.
    If you are going to get a disposable camera, get one of those new kodak High Definition film ones, I'd imagine they will take better pictures.
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Just buy a budget 35mm compact - not any of this APS rubbish
