Still hairy pj
Discussion in 'Projectors, Screens & Video Processors' started by triumph, Feb 12, 2005.
  1. triumph
    triumph
    Feb 10, 2005
    And I was soooo confident that the combined efforts of the air duster
    and dyson would shift the little blighter, but the little green hair remains
    at the bottom of the screen, waiting for every dark scene so that it
    can wave its contempt for my efforts in the breeze from the fan.
    Would I be correct in assuming,because of its colour and position on
    screen, that it is trapped at the base of the green lcd panel? any ideas
    on how to get rid of it? Nobody as yet has posted advice on how to
    remove the top case from a PJ TX100. The man with the same name has
    suggested removing the lamp housing, presumably to provide access for
    further attempts with an air duster, any views on this? he also makes
    mention of an improved air filter for this model, in view of its escalating
    reputation as a dust magnet it certainly appears to need one
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    As PJ says it's more than likely that it got there before you bought it, why don't you get Hatachi to deal with it and get you a loaner in the mean time?
