Still can not transfer from PC to XBOX
Discussion in 'Xbox Forums' started by dUnKle, Sep 11, 2004.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,618
    +2,489
    I used to be able to - in fact I have transfered many a thing from my PC to the XBOX via my DLink router - however that has recently all stopped !
    I have tried direct connection via WinXP, Filezilla and FlashXP and none of them will connect
    IP settings of XBOX is 192.168.0.1 and as far as I know password and user is still XBOX
    None of this has changed and these are the settings I am using
    The only thing to change has been a fresh install of WinXP
    Can anyone help ?
  2. mitch
    mitch
    Sep 6, 2003
    5,450
    +662
    this may sound daft but i can only connect to my xbox if i am using xbmc.if i try connecting when i am on the evox dash it wont connect
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,618
    +2,489
    Thats certainly oen for the to b tried box - thanks
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,618
    +2,489
    nice try but did not work :(
  5. mitch
    mitch
    Sep 6, 2003
    5,450
    +662
    which dash are you using?
  6. fingery
    fingery
    You say fresh install of XP....have you also installed SP2?? If so, check the firewall settings.
  7. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    are you using port 21 for communactions, and are you sure the xbox is 192.128.0.1, if you're using a router that will obviously change (e.g .1 for port 1, .2 for port 2, etc)
    probably no help but try Xbox-Scene and those lot are alot more knowlegable on FTP than myself.
    Rich
  8. ado
    ado
    Nov 6, 2003
    192
    +6
    this happened to me - just couldnt fathom it out.
    it used to work then it never - until i disabled my internet connecton on the control panel.
    i think it was using the internet to log on not the network card
