Stiff Fabric
Discussion in 'Projectors, Screens & Video Processors' started by David_of_Surrey, Mar 19, 2005.
  1. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    201
    +6
    after the success of my first screen I'm going to make another , It will be of the same style, a rod top and bottom, and to store simply roll it up. This time I will buy some proper fabric.
    What I'm looking for is some fabric (gain about 1.0) that is quite stiff to roll, eg I would say as stiff as a sheet of 80g/m paper, (when you hold the paper on an end it droops under its own weight around an approx radius of 40mm or so)
    Does anyone have any ideas? apart from paper that is
    Dave
  2. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    201
    +6
    I'm wondering about tyvek or matt polyester plotter media, both are cheap, dead flat pretty indestructable and shouldnt wrinkle , any thoughts?
  3. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    201
    +6
    I'm still wondering about tyvek, this is available a large rolls, has anyone tried it for a screen?
  4. paul1967
    paul1967
    Dec 26, 2005
    1,258
    48
    +65
    You would have to use the grey side as the writing on the white side of the tyvek. the widest I've seen is 1.5m.
    paul1967
