Sticky situation?? PWD6 stand
Discussion in 'Plasma TVs Forum' started by JustCruzin, Jun 8, 2005.
  1. JustCruzin
    JustCruzin
    I'm need of some help here. I purchased an RCA component board for my PWD6 :) which is bolted on to a panasonic display stand sitting on an Atacama audio equinox AV shelf (toughened glass). The stand appears to have somehow stuck onto the glass :eek: (I swear I never used glue or spilt anything).
    Any attempt made to lift the screen up drags the glass up with it and currently I am too scared to lift it off completely for fear of severing vital organs ;)
    Now you may all be saying why don't I get behind the screen. Well... if I was about 83% thinner and double jointed maybe I could... just about..
    Has this ever happened to anyone else out there OR does anyone have any suggestions preferably without using harsh chemicals and crow-bars? Any advice would be very appreciated
    ARIF :cool:
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I would get a spatula and go round the edges of the stand gently edging inwards all the way around the stand, that should do it.
    Are you sure you didn't get too excited when you got it :D
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    or get a couple of burly mates round to hold the plamsa while you unbolt it, lift it off and fit board then bolt back on.........
  4. stevelup
    stevelup
    Aug 13, 2002
    6,507
    Swindon
    +1,080
    You could try heating around the stand with a hairdryer. That should loosen up whatever has got sticky.
    Steve
