Sticky Paper
Discussion in 'Movie Forum' started by thfccambs, Jan 22, 2003.
  1. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    I an looking for some paper where i will be able to print on and then stick on to a disk.any links would be helpful.A4 size paper aswell
    cheers:)
  2. letitbleed
    letitbleed
    Nov 5, 2002
    221
    Southampton
    +9
    Have you thought of using CD labels,although it is not recommended to stick anything on your discs !!!
  3. bobbles
    bobbles
    BIG
    they have some kits
    they also sell -R that you can print onto and the printing kit
    I can recommend the Yellow 50 -R they sell v cheap and work a treat
    that sounds a bit too david dickinson:eek:
