Sticky on explanation of display types?
Discussion in 'Televisions' started by nathan_silly, Mar 4, 2003.
  1. nathan_silly
    nathan_silly
    Wondering if a sticky can be made up with the major display types (Plasma, Front CRT, Front LCD, Rear CRT, Rear LCD) with pros and cons of each type- for example, LCD has hot bulb which is expensive to replace...
    Nathan
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    I'm not a great fan of stickies as they can end up making the forum look clutered.However if there is enough demand ...
