Sticky keyboard.
Discussion in 'PC Gaming & Rigs' started by BadAss, Dec 19, 2003.
  1. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Has anyone else had this problem. Its when playing something like Halo or Unreal2 when Im moving and have multiple cursor buttons pressed. Eg, I can have my finger down on the forward cursor then if i press the left cursor at the same time i would expect to move in a diagnal direction. This doesn't happen I will either stop completly or just straf left. ??? This only happened when I changed to XP and ive checked my keyboard on my old PC and its fine. Any ideas guys? Also when I hit the tab button to get the scores in CS the menu flashed twice as if it registers two key strokes.
  2. andy572
    andy572
    Dec 4, 2002
    361
    Oop North
    Either a dying (or dirty!) keyboard, as happened to me a few months ago or...
    it's the 'keyboard matrix'!
    That sounds better than it is :rotfl:
    Some (old or cheap?) keyboards can only register a couple of simultaneous presses and can't even do that if they are in the same 'cluster' of keys (the matrix!). My last couple of keyboards (included with each PC) were like this. I haven't played any games with it, but my relatively new Microsoft Natural Multimedia 'board doesn't appear to have the problem.
    Some of that might be right! :laugh:
  3. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    Are you sure it's not the XP "filter keys" or "sticky keys" kicking in ?
    To disable go into control panel, then accessibility options and disable stickykeys and filterkeys.
    Hope this helps
  4. andy572
    andy572
    Dec 4, 2002
    361
    Oop North
    I don't have the hardware for XP, but have bumped into mention of 'Stickykeys' a few times. Is the default set to 'on', John?
    Edit addition:
    I don't yet have the hardware... :(
    :D
  5. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    I believe the default is "on". I've come across it a few times when typing on a fresh install of XP. I tend to hold down the shift key whilst I'm thinking of the sentence I'm going to type (for the initial capital letter) and the annoying pop-up comes up.
  6. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Went into the accessibility settings and tuned the sticky keys on. Not played much so far but I think its sorted the problem.
    Cheers guys and a Happy XMas.
