stewart screen really worth 3x
Discussion in 'Projectors, Screens & Video Processors' started by marcoeser, Jun 14, 2005.
  1. marcoeser
    marcoeser
    Jul 17, 2000
    340
    Hi, im looking for a 110" 16:9 fixed sceen screen. Ive found that the Stewart screen is 3x the cost of other screens. Is it really worth it?
    marc
  2. Timmy C
    Timmy C
    Oct 10, 2003
    4,523
    +219
    I guess it depends on your projector. If you've spent 25 grand on a top of range Sim2 or something similar then you'll want to get the best from it. On the other hand you maybe better off with a cheaper screen and putting the money you save towards a projector upgrade. You should certainly try and demo a Stewart with your own pj before considering spending that sort of cash though!
  3. marcoeser
    marcoeser
    Jul 17, 2000
    340
    im getting the Marquee 9500LC Ultra CRT projector
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Stewart StudioTek 130 then :) Your LC deserves the best
  5. Jules
    Jules
    Oct 11, 2000
    5,096
    +768
    Not sure about being worth 3 times the cost, but I have Stewart Grayhawk screen which is probably considered old hat now, but it is a truly excellent screen.
    From what I've seen, Stewart screens don't just give better contrast, brightness, viewing angle etc (depending on the material you choose), but also seem to have a smoother surface that helps give the image a nice smooth, window like appearance.
    I recently considered downsizing my screen (to better fit the room layout), but I couldn't afford another Stewart.
    When I investigated cheaper replacements, I came home and re-arranged the room making damn sure the Stewart stayed put.
    Once you've had a Stewart, it's pretty hard to go back.
    I admit I havn't seen all the competition, but what I have seen at the cheaper end of the market doesn't really compare.
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,469
    Surrey. UK.
    +2,117
    I posted a comment here which might help a little:
    http://www.avforums.com/forums/showpost.php?p=1746763&postcount=19
    Stewart has won 2 Oscars for it's contribution to the world of movies (inclusing the invention (?) of the Green Screen), as well as other accolades, and with excellent customer service, you can see why they cost that bit more.
    Of course, Rip Off Britain means our dealers pay more for them at trade price than Joe Public does at retail in the USA, but that's another story.
    Gary.
