Stewart Screen Question
Discussion in 'Projectors, Screens & Video Processors' started by cj, May 2, 2003.
  1. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    Does anyone know the model number of the Somfy IR controller supplied with the Stewart Luxus ModelA electriscreen? I could take a look, but it's installed in my ceiling and I'd have to take my floorboards up...
    Cheers,
    Colin
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Are you looking to learn the remote or find a replacement etc. ?
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  4. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    I need the model number as I'm about to buy an electric blackout blind to go behind the screen. The one I'm looking at is controlled by a Somfy IR controller IRS100, which I suspect is the same controller that controls my screen. I'd like to be able to operate them independently, so I need a Somfy IRS300 which has selectable IR channels (up to 8). This is more expensive, but if by some miracle the screen already has one of these, I won't need to get one with the blind.
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
