I have a Stewart Grayhawk microperf 100" fixed screen which I bought second hand. I thought it was a bargain but I've just done some very last minute research and am now very worried that it is not suitable for my room.
The THX recommended viewing distance ifor a 100" screen is 3m (or 10'), and this is where I intended to view from.
Unfortunately I have just discovered a Microperf White Paper which says "As an example, in a conventional theatre, with a luminance level of 12 Foot Lamberts (nominal), the studio industry standard Stewart Cinema Screen will have the perforations vanish at a viewing distance of 15 feet whereas the Stewart MicroPerf fabrics will vanish at a viewing distance of 12 feet."
If I move my viewing position back 2' to 12' I will be just 1' from my rear wall, directly below my in-ceiling rear surrounds. I can do this but it is not ideal. Does anyone have any idea how visible these microperfs will be at 10' in a dark light controlled room? Will it completely ruin the experience. My PJ is the JVC HD1 which outputs at 1080p.
My other problem is that I intended to put my Centre speaker about 7" behind the screen, taking advantage of its acoustic transparency. Again unfortunately, the same White Paper says "The speakers behind the screen need to be a minimum of 12 inches away from the rear surface for the best performance. They found that if the speakers are closer to the fabric, comb filtering can occur but when installed to specification, minimal attenuation occurs permitting truly transparent audio"
Any idea how serious this comb filtering (whatever that is) will be in my set up? Will it significantly impair the intelligibility of the dialogue?
My builder is constructing my front stud wall in 2 days, so I need to confirm the design today or tomorrow. Specifically, should I give up on the idea of putting the Centre behind the screen and instead put it below? If I do this then I will get no benefit from the screen being acoustically transparent
I'm beginning to think my screen was not such a bargain after all - I hope someone can reassure me on both the above 2 points.
