Trying to work out the difference...
I get that Direct bypasses all the tone controls, but I currently have my subwoofer turned ON for Stereo/Direct...when I select stereo, the frequencies below 80Hz go to the sub and I can verify an input into the sub. When I select Direct, the right hand side indicates SW output, but the sub doesn't receive any input. What is happenning?
With Pure Direct nothing goes to the sub as expected, otherwise does Pure Direct just equal Direct with the display turned off?
Thanks, Ben
Thanks, Ben
