I want to use my system for 5:1 movies and for CD Stereo music.
I have a Denon AVR-3802
Using the Pre-Out Sub Woofer I want to connect this to a
Technics SA-GX100L which I want to use as the amp to drive a passive woofer rated 3 OHMs. (what kind of cable connections do I need?)
A or B speaker outputs on the Technics are rated at 4-16 OHMs per speaker.
Two More Questions:
1. Can I run the 3 OHMs woofer connected to the speaker outputs without damage to the Technics?
2. How do I combine the Stereo Left and Right channels so that they can drive the mono woofer which has just a pair of spring clips connections +/-, Any helpful wiring diagrams and advice would be much appreciated.
Two More Questions:
