MA tend to make their lower range speakers now with a 50/50 approach to hifi/home cinema in mind....simply because just to concentrate on hifi is a small market and overloaded with choice...therefore not very profitable...
i bought a pair of MA Silver S6's, then a few months later bought a Denon 3803, then half a year later added a centre and rears (SLCR and SFX's, i used a cheap pair of Missions for rears and Gale centre from Richer sounds while i waited for more money to buy the matching MA's).....then added a better sub, then a bigger sub...heh....oh yeah and at some point a Denon 3910 DVD player, then eventually a projector.......and my setup absolutely spanks the bum off what i could have bought up front in one package initially.....the BR6's are towers of power type stuff, feed them well and sit back for a stupendous movie experience, especially once you get the matching surrounds....altho one thing i would possibly suggest is to consider the Silver range centre over the Bronze.....not sure about the BR centre, but the previous B centre version was a little weak, specially when paired with the largest floorstanders in the Bronze range.....the RS silver centre will handle similar volume loads easier........
so to summarise what i've babbled about, if you wont be able to upgrade for a while but would like a bit of surround in the meantime, pop to Richer Sounds or go second hand for a cheap pair of rear speakers and a centre, dont pay more than £70 for the lot, and grab a decent AV amp around £400 for now, make sure it has pre-outs and use your current stereo amp for the BR6's.......then, when proper funding presents itself, get the BR centre or consider the RSLCR centre, then either same time or if not whenever add the BRFX's, then grab either a Monolith or PB10 sub, or save up a bundle for a stamping great PB12/Plus or Plus 2.....heh......given the rather stupid volume levels the BR6's can reach, it may be worth considering the larger SVS, the Monolith should hold its own pretty damn well, but the Plus or Plus 2 will definitely match them.....
then, get a pair of MA's Platinums when they are released and a £1,500-3,000 stereo amp and high end CD player for a dedicated hifi setup.....bwahahaha....heh..sorry, couldnt resist mentioning it....im so glad i got my new job.....clear some space on the cards and those Plats are mine!!!
back to sanity now.....enjoy the setup whatever you end up with
edit: forgot to mention, MA do cinema very well due to their speakers generally approaching sound with a clear studio monitor kind of sound, although not completely, so they suit home living music too.......they are a good compromise if you dont fancy M&K type setup......they are especially good with vocals and car crashes
