stereo subs
Discussion in 'Subwoofers' started by upallnight, Aug 26, 2003.
  1. upallnight
    upallnight
    Jun 11, 2003
    1,817
    63
    watford
    +107
    can someone tell me how you set up to have 2 subs connected.i have a thx reciever, but only 1 sub output as far as im aware...thanks
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    You will need a Y connector so that the one output can be connected to two single sub cables
  3. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    Hmmm if you use 2 subwoofers the subwoofer sound it split into L and R isn't it...
    I too only have one Pre - out Sub Output...never really thought of using 2 subs but if you don't have 2 sub outputs on your amp I can't see how you can do it.
    Does the sub instruction manual not give you a helping hand???
  4. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    Or you could just do what Ian J said.
    I have a split Y cable but I run them both into the sub - L and R.
    If you wanted 2 subs with L and R on each of them does that mean spliting the cable again with another Y meaning 3 Y connectors.
    Would that work?
  5. upallnight
    upallnight
    Jun 11, 2003
    1,817
    63
    watford
    +107
    never seen anything in the manual, it seems strange that thx recommend 2 subs but dont show you how to connect them.you would have thought there would be menus to set them up if you wanted!
  6. upallnight
    upallnight
    Jun 11, 2003
    1,817
    63
    watford
    +107
    surely someone must be running 2 subs?
  7. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    I hope your room is big enough to run them if you are gonna run 2....
  8. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    This is copied from Ian J in a previos post just on page 2.
    You will need a Y splitter to connect two subs to one amp but beware the Ixos splitter sold by Hifibitz isn't suitable as you need one male plug at one end and two female plugs at the other from which you will run seperate phono leads to each sub.
  9. upallnight
    upallnight
    Jun 11, 2003
    1,817
    63
    watford
    +107
    thanks for your advice
