Stereo from Humax pvr-8000t?
Discussion in 'Digital TV & Video Players & Recorders' started by mischi p, Jan 2, 2005.
Tags:
  1. mischi p
    mischi p
    Got a few problems linking up a surround sound package to the Humax freeview stb. How can I tell that the sound coming out is stereo (apart from listening of course!)? Got it set to stereo and dolby digital from the menu setup but still not one 100 % convinced.
  2. kdp99
    kdp99
    Mar 29, 2001
    196
    Southampton,Hants,UK
    +20
    There is a bug in the later firmware that plays back recordings in mono, but live broadcasts in stereo.
    To get round this each time you play back a recording press audio, then the button in the middle of the cursor (not sure of its exact name as I use a multi-remote)
    Hopefully updates will fix this
    Keith
  3. Cablechap
    Cablechap
    Oct 22, 2004
    142
    +6
    I've got exactly the same problem on my 80GB with latest software.
    My audio connection is via optical S/PDIF, but does the problem still arise via analogue output left and right? If you look at the manual p13, it shows both optical and analogue connections at the same time on connecting Hi-Fi system 2, weird!
    Bring on the new software update.
    Cablechap
