Stereo extension cable with volume and track change/ audio streamer
Discussion in 'Headphones, Earphones & Portable Music' started by adamCCC, Jul 17, 2015.
  1. adamCCC
    adamCCC
    Aug 27, 2009
    305
    +12
    Does anyone know where I could get a stereo extension cable that has volume control and the ability to skip between tracks?
    I can find plenty with volume, but none with both. Does this type of cable even exist or would I need to go with a bluebooth streaming adapter? The problem with that is that it would need charged regularly, can you get ones that use the power from the phone?
    I want this so I can skip tracks on my phone whilst cycling, as my phone is in a waterproof case which isnt touch sensitive.
    Thank you
    Adam
  2. Kev Greenhalgh
    Kev Greenhalgh
    May 3, 2012
    588
    5
    25
    96
    Manchester
    +741
