Stereo Direct via remote on AVR300
Discussion in 'AV Receivers & Amplifiers' started by GarySargent, Jan 23, 2005.
Tags:
  1. GarySargent
    GarySargent
    Jan 19, 2005
    61
    +5
    Anyone know if there is a way with the AVR300 to switch between Stereo Direct on/off using the supplied remote?
  2. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,431
    Cornwall
    +100
    only way i know is to bring up the quick setup menu (probably not the right name, but it's the same button you have to hold for 5 secs to bring the full configs) and change it there.
  3. Hifi addict
    Hifi addict
    I already asked this question 2 months ago and john or andy would address it to engineering and it would be entered in 1 of their software updates
  4. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    There is no way to switch direct from the CR80 without entering the main menu (single press of the menu button). It is about the thrid or forth option down in that menu.
    However if you are using a Programable remote such as a Pronto there are now descrete codes to turn the direct mode on and off (codes 16 - 78 on and 16 - 79 off or toggle on-off 16 -10)
    Regards,
    Andrew
  5. GarySargent
    GarySargent
    Jan 19, 2005
    61
    +5
    Andy is there a reason why pressing the AUX on the CR80 (which switches to PVR?) doesn't turn the amp on, but other inputs do switch it on? Is this a bug maybe or by design for some reason?
  6. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    Mr. Dutton, allow me to retort. DIRECT is a "mode", is it not? Therefore it should be another option in the "MODE" button.
    It should also be called "Direct Analogue" since it applies only to analogue inputs.
    It can have advantages playing vinyl and high-quality tape decks. These are the only analogue devices still around. There is no phono input in the A300 and arcam does not market the phono Module standalone.For CD what this means is: use the Players DAC, bypass AVR300 Dac.
    Since the DAC's in the AVR300 are far better than 95% of the CD Players around, the best way to play CD is via digital Coax input. Unfortunately the mode "stereo" seems to go through the DSP, according to one reputed reviewer, from the USA.
    If that is the case, then what is needed is a mode that feeds the SPDIF signal straight to the DAC, which has the problem that if you play a compressed recording (Dolby Digital, etc) you hear horrible noises.
    One can't have everything...
