Stereo ariel cable
jat1964
I have a phillips DAB portable radio.....very pleased.....i would to connect it to a portable speaker....3.5mm......i have tried a normal cable with no joy
Any idea's
cheerz
jat1964:lease:
Chris Muriel
What is the Philips make and model ?
Are you trying to connect to a pair of speakers ?
The jack socket should be a 3 pole stereo type.
Chris Muriel, Manchester
jat1964
Hello
It's the phillips DA1000......The ariel is in the headphone cable.....I have a set of mini creative speakers that i would like to connect to the phillips
I thank you
jat1964:D
Chris Muriel
Philips customer care say that you should can only use the supplied earphones because of the aerial.
This isn't totally true as I know of someone who tried some Sennheiser headphones and they worked fine.
The length of the headphone cable will make a difference in the strength of the signal you pick up.
Just be aware they may not work perfectly in all situations e.g. out and about in a built-up area.
External speakers should work, since they have a long lead, although you may have to position the cord in such a way as to get a good signal i.e. stretched out, not coiled up.
It's the lead that is acting as the aerial in both cases.
DAB digital radio actually makes use of multipath signals - analogue radio suffers from interference in the same situation.
You may also be able to use headphone splitters to add an extension aerial wire.
jat1964
Thanks for your comments...... i have tried the 3.5mm stereo cable that came with the speakers.... no joy at all..... wondered if i could get a set of headphones adapted????
cheerz
jat1964:thumbsup:
Chris Muriel
I am not sure whether you mean the speakers don't work electrically in the audio sense (no sound , not even a mild hiss on full volume) or not working as an effective antenna - no signal.
If no signal, try my suggestion of using a jack splitter with more wire connected to the spare port.
ProfessorYaffle
I've got a Bush PSBAB2004 and tried the wife's £4.99 Wharfedale passive speakers from Argos. Worked a treat. These are powerless (I understand powered speakers play havoc with the DAB signal, if attached). Other forums also suggest that 3.5mm jack splitters will not work effectively either for some technical reason.
The Wharfedale's won't give you stadium sound obviously, but are good enough for the casual listener - being Argos, you could get some, try them out & take them back if the Philips has issues with them. Can't see why it should as most DABs use very similar circuitry.
Out of interest, swapped the bundled 'phones for a Sennheisser pair and had no issues there either (but I am in a strong signal area). The difference in sound quality is very noticeable...
jat1964
That's the reason then...powered speakers..... will try the passive type..... what was the other headphones u tried please
cheerz
jat1964
ProfessorYaffle
Mine are Sennheisser MX300's - not top of he range, but far better in-ear phones than those supplied on every audio device I have ever owned. Got them in Singapore whilst there, but you can get them for less than a tenner online.
