norliss
My subwoofer is currently connected to the sub-out connector of the AV amp as is pretty standard, but I'm in the process of moving back to a stereo amp. I understand that it's considered better to use a high-level connection to connect to the speaker terminals and I still have the required cable supplied with the sub.
However, in the manual of my prospective amp it clearly states "Do not connect your active subwoofer to the SPEAKERS L/R CH terminal. Connect it to the PRE OUT jacks." Any idea why this might be the case?
Assuming I do go via the pre-out jacks, would it make much difference if I used a stereo -> mono phono adapter and stuck with a single mono run or would I see much benefit in using two separate cables for each channel?
