Stereo amp around £500?
Discussion in 'AV Receivers & Amplifiers' started by Daneel, Jan 2, 2004.
  1. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    I'm considering upgrading my speakers to something like B&W 704s, possibly 804s or 9 NTs second hand. I've also been told to consider the Quad L range and I'm having a listen to the MA GR20s. I will add a CD player in a few months once the funds come together (just use DVD player for the moment).
    Up for consideration so far are:
    Arcam A80/85
    Roksan Kandy MK III
    NAD 372
    Marantz PM7200 / KI Signature version (struggling to find out what justifies the large price gap between these)
    Are any of these suitable, what else should I consider?
    Anyone know of 2nd hand kit around that I might pick up?
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Would definitely recommend Rotel's RA-1072, which is just stunning - both aesthetically and in performance. I think it retails over your budget though, at £595. But it's worth the extra, and would have no difficulty driving the speakers you mention you're considering buying.
    How much of an improvement it is, however, over your VSX-D2011, has to be considered. To significantly better your receiver in stereo I'd imagine you'd need to spend a little more than you've budgeted for.
    I haven't compared the stereo performance of your Pioneer and such Rotels, so am only guessing. I'd advise you to 'borrow' an amp from your local dealer before making any descisions though.
  3. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    You can pick up a second hand Arcam FMJ A22 for around £500. Better than an A85 and beats my Pioneer 2011 hands down in stereo.
  4. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    Godfather, can you point me in the direction of such a deal?
