Stepdown advice for GC
Discussion in 'General Video Gaming Chat' started by tryingtimes, Mar 20, 2002.
  1. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Hi all
    I've just brought back a GC from Canada (£130!) and thought I could use the stepdown that I use for my american dvd player.
    Last night the GC picture crashed and the light on the GC started pulsing!
    Could this be the stepdown transformer being insuficiantly powerful and overheating?
    If so what rating should I look for on a replacement stepdown.
    Many thanks
    Alex
  2. Zone
    Zone
    Jun 24, 2001
    6,775
    Barnsley
    +2,507
    Could be that the step down isn't powerful enough, that being the case the console draws the amount of power it needs from the step down itself and if its not up to the job it'll end up blowing. Had a search for you and NTSC-UK suggest a step down power rating of not less than 50watts 30% more than the console.
    Happy gaming..
    Si
  3. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Yep - my local gameshop was selling ones that actually said Gamecube Stepdown on and they were rated at 65 watts. (mine was 30W). I bought one as they were only £15 and seemed like a likely culprit.
    Alex
  4. Taz
    Taz
    our step down is rated at 30Va on our GC and works just fine.
    if thats any use;)
    Taz.:cool:
  5. museumsteve
    museumsteve
    Jan 28, 2001
    7,982
    4
    Nth Hampshire
    +1,094
    30vA is 30watts..
    A GC has a rating of 39watts so a 50watt+ is a safe bet..
  6. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Yep - mine was 30Va too (tacima) and obviously gave me problems as I've not had a problem since replacing.
