A Steinway Lyngdorf thread seems overdue, so here is my attempt to describe their benefits.
Steinway Lyngdorf combine a range of technologies that remove the distortion found in other audio systems. They are only available as complete systems, but these systems will outperform any other combination of stereo or surround components.
The Technology
Steinway Lyngdorf remove the noise and distortion inherent in other audio electronics. Their patented amplifier technology, Equibit, directly converts digital PCM audio to the PWM analogue signal required to drive loudspeakers. This eliminates the need for a pre amplifier and the additional layers of A/D conversion found in other systems. Listen to a Steinway system and you’ll hear it is completely silent and will reproduce your music and movies with nothing added or taken away.
Reproducing bass accurately is one of the most challenging problems in home audio. Steinway have solved this problem with the addition a new category of speaker, the boundary woofer. Placed in pairs in the front corners of the room, all the sound they produce arrives at the listener position without secondary reflections from the room. This placement combined with a linear response to over 1000Hz and RoomPerfects’ unique design delivers better timing and quality than any alternative. Listen to some drumming, percussion or content with strong transients and you will hear the difference.
Speaker cabinets create unwanted resonances that colour the sound from the drive units. As the air in the cabinet is compressed, this restricts the movement of the drive units. Steinway have removed both these problems by producing speakers without any cabinet. A solid billet of aluminium holds the drive units in free air for the fastest, cleanest response. The open, dynamic sound this produces sound like the live event, rather a loudspeaker trying to reproduce it.
The weakest link in a good hifi or home cinema is the effect of the room’s acoustics. No amount of room design and treatment can remove the errors that the listening room creates.
Steinway Lyngdorfs solution is another patented technology, RoomPerfect, the worlds most advanced room compensation system. This process is unique in preserving the characteristics of the loudspeakers used while removing the acoustic errors your room creates. Designed to give optimal sound in normal, untreated rooms, RoomPerfect makes it possible to achieve the finest sound quality throughout a home.
Testing the Results
Steinway Lyngdorf are the only audio system capable of reproducing the live performance while their surround system deliver higher quality that the finest professional systems.
If you would like to put these claims to the test, please get in touch.
To find out more, visit the Steinway Lyngdorf website here
steinwaylyngdorf.com
The Technology
Testing the Results
Welcome to Steinway Lyngdorf | Steinway Lyngdorf | The world's finest audio systems
Steinway Lyngdorf brings together Steinway & Sons, makers of the world’s finest pianos for more than 165 years, and Peter Lyngdorf, one of the most forward-thinking audio innovators of our time. Steinway Lyngdorf provides fully integrated digital audio systems that combine design artistry...
