steering?
Discussion in 'Motoring' started by imhotep69, Sep 8, 2007.
  1. imhotep69
    imhotep69
    I have a ford ka and the steering wheel creaks when i turn it, and then the steering goes harder then back to normal after a few seconds, its not powered steering modle but dont know what it is can anyone help?:(
  2. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    Interesting first post on an AV forum.
    In any case,you need to get this looked over by a competent mechanic.
    ANY steering or other safety related item on a car needs to work properly,and if the steering is creaking and stiff,the steering rack may be damaged.
    The possible consequence is obvious.
