steering wheel drivers?
Discussion in 'Xbox Forums' started by evilash, Dec 31, 2006.
  1. evilash
    evilash
    Dec 11, 2002
    803
    brighton
    +74
    I have just got the steering wheel for the 360! my question is this. Should the wheel feel as loose as it does or is it something to do with the drivers which I think havent loaded onto the 360! any help greatly accepted cos right at this moment it feels like £90 down the pan...........
  2. BFassassin
    BFassassin
    Sep 27, 2006
    294
    +10
    How do you mean? when it is not connected it is very easy to turn but once connected to the console it is a lot harder to turn for me anyway
  3. evilash
    evilash
    Dec 11, 2002
    803
    brighton
    +74
    thats what i mean! its just the same! no resistance!! does the driver have to be installed for this function to work? mine definitely didnt install any drivers off the disc or at least it wasnt obvious!
  4. Mattk84
    Mattk84
    Feb 20, 2006
    3,547
    Weymouth,Dorset
    +135
    doesnt the force feedback feature only work when its clamped to a table ?
  5. Anotherlimey
    Anotherlimey
    Nov 6, 2005
    6,113
    2
    Portsmouth
    +930
    As far as im aware the force feedback only works while the wheel is plugged in to the mains.
  6. Jay
    Jay
    Jun 25, 2006
    17,637
    on the battlefield....
    +2,081
    Firstly the manual says that when you insert the disc in, a message appears that the installation is complete...No message appeared. But i've been told all it is is an update to support the wheel which was included in the last dashboard update. The disc is only for those without internet connection. So that is why a message won't appear. Also another limey is right, the wheel needs to be plugged into the mains for forcefeedback, the batteries are only for rumble, so the wheel will be loose and just rumble the same as the controller would. Do you have it plugged in. Also remove batteries before pluggin mains unless it is a battery from the play n charge kit as the wheel recharges it.
  7. Jay
    Jay
    Jun 25, 2006
    17,637
    +2,081
    Also i wonder whether there will be an update to adjust forcefeedback etc or whether it will just be specific game options. I'd love more forcefeedback, until my wrists break i won't be happy ;)
  8. Mattk84
    Mattk84
    Feb 20, 2006
    3,547
    Weymouth,Dorset
    +135
    thats what i meant !:rolleyes:
    I knew there was something that had to be done to get the wheel to work fully.
