Steering Wheel Advice
Discussion in 'Playstation Forums' started by JtR1888, Feb 12, 2009.
  1. JtR1888
    JtR1888
    Mar 19, 2008
    1,394
    +61
    Hello there peeps. Im new to the PS3 franchise as for the last few years Ive been an Xbox user, however, since Santa came with a PS3, I thought Id get a wheel
    Im torn between 2, both Logitec
    Either Driving Force GT or the G25
    Around £70 difference in price but I would rather spend on whats worth it than saving a buck or 2
    Can any1 advise me which way to go, primarily will be used for GT5
    Ive already read 100's of reviews, they all seem good. The G25 does seem the best build but then the DF GT has the adjustment wheel for ingame car adjustments specifically designed for GT5
    Help me please,
    Appreciated,
    Lee
  2. demoni
    demoni
    Oct 16, 2007
    79
    Northampton
    +4
    If it were my money then I would get the G25 looks schweet!!
  3. Tall_Paul
    Tall_Paul
    Dec 3, 2005
    8,567
    Kent
    +2,172
    Seconded for the G25, I had one, they are a quality peice of kit. You might might be able to pick one up from the classifieds on here for under £100 :thumbsup:
  4. JtR1888
    JtR1888
    Mar 19, 2008
    1,394
    +61
    Cheers for the replies but what makes the G25 better, is it just the build ?
  5. StuMcGrath
    StuMcGrath
    Jun 11, 2003
    48
    Gourock,scotland
    +5
    G25 has got a clutch pedal & H-shifter which the GT doesn't have...
    have you thought about this wheel if you have an xbox aswell....
    even more expensive but works on xbox,ps3 & pc
    >>>Fanatec.com
  6. JtR1888
    JtR1888
    Mar 19, 2008
    1,394
    +61
    Thanks for the link but I dont suspect I'll be using my 360 much more ;)
  7. StuMcGrath
    StuMcGrath
    Jun 11, 2003
    48
    Gourock,scotland
    +5
    no probs....
    just thought you might be picking up Race Pro on the xbox if you were into driving games...
  8. JtR1888
    JtR1888
    Mar 19, 2008
    1,394
    +61
    forgot about that one lol, now u got me thinking. Damn damn damn. I might get the GT & a 360 one now, I dont really like dual comptibility stuff, they dont always respond both ways if u know what I mean
  9. JtR1888
    JtR1888
    Mar 19, 2008
    1,394
    +61
    Just had another look at that Fanatec site, they do say that some PS3 games are compatible but cant be guaranteed - def gonna steer clear & probably buy both the 360 & the GT wheel, decisions decisions lol
  10. redwinnie
    redwinnie
    Aug 15, 2008
    1,539
    116
    Kent
    +631
    I've got the driving force pro (I think it's called) the older version of the gt pro. I decided on that cos £160 for the G25 is way to much for me. The force pro still has double motors and the biggest difference is the lack of clutch pedal and gear stick (if you can find a game on ps3 to make use of them). It still has the flappy paddles though and I got it for just under £50 on ebay. I would defo recommend it, especially if it not being used lots. I decided that if I liked it and used it a lot I would sell it and buy the G25 but I'm more than happy with it.
  11. JtR1888
    JtR1888
    Mar 19, 2008
    1,394
    +61
    Wise words Red, I think I'll get the GT for £85 & like u, if I feel the need for better, I will look around afterwards.
  12. kendoll
    kendoll
    Nov 28, 2005
    3,789
    Sydney
    +551
  13. JtR1888
    JtR1888
    Mar 19, 2008
    1,394
    +61
  14. kendoll
    kendoll
    Nov 28, 2005
    3,789
    Sydney
    +551
    You are most welcome. :)
