Steel Battalion- where can I buy it?
Discussion in 'Nintendo Forums' started by wigman15, Jun 18, 2004.
  1. wigman15
    wigman15
    I am trying to buy the Steel Battalion Line of COntact game + controller but I cannot find anyone that sells it. Does anyone know where I can buy it?
  2. Jason S
    Jason S
    Loads on Ebay.
  3. Pooon
    Pooon
    Dec 26, 2002
    7,120
    Canterbury, Kent
    +723
    Gamestation sells it, £119 i think. and most GAME stores can order it afaik.
  4. Lameway
    Lameway
    Mar 29, 2004
    67
    West Midlands
    If you're anywhere near Cardiff, the CEX by Central Station has a 2nd hand one in the window
  5. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,516
    2
    Manchester
    +4,313
    I had the same problem a few weeks back. I spoke to and emailed Game they replied that they no longer take orders as it is no longer manufactured, and a central database search returned no UK stores having one in stock. I doubt this has changed. Gamestation couldn't even be bothered to do a search for me. I eventually got a returned one from HMV Manchester by chance (with 10% discount as it wasn't first hand).
    If you ask the chain stores (like HMV) they can do a central stock search. They would usually transfer it free of charge to your local store, depending on how generous they're feeling. Otherwise eBay is your best bet, but when I checked a few weeks back they were going for £175-200 (in good condition), so make sure you've tried all other options first..
  6. anephric
    anephric
    Mar 23, 2002
    1,048
    Derby
    +149
    Someone at my work was in a Dabs.com warehouse and spied they had two, so bought one.
    The moral of the story is try dabs.
    regards,
    anephric
  7. anephric
    anephric
    Mar 23, 2002
    1,048
    Derby
    +149
    wwww.playasia.com have NTSC ones for £110: don't know what the shipping will be (prob about £20-30 so will be roughly what the RRP is over here).
    regards,
    anephric
