Stealth sky+
Discussion in 'Sky Digital TV Forum' started by Dak, Oct 28, 2003.
  1. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    I am living in a conservation area and am not allowed to install a dish. Has anyone used these products? Do they work? Can I get Sky+ with them? Thanks
    http://www.digicams-uk.com/prod235.htm
    http://www.digicams-uk.com/prod30.htm
    Oh, and if I go for something like this then I am looking at a run of about 35 feet between the satellite and the box. Is this a problem?
    Ta
    Dak
  2. shawkins002
    shawkins002
    Dec 12, 2002
    237
    Epsom, Surrey
    I use something very similar to the first one - a cubsat 70. Looks the same thing - I got mine from www.bradleywood.co.uk.
    Works perfectly with Sky+ - I fitted a quad lnb myself. I get about 75% signal strength and quality, without using a satellite meter to install it - just moved it about until I got the best signal.
    A 35 ft run should be OK - as long as you don't have too many joins in the run.
  3. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    Thanks, how did Sky cope with your request etc?
    Will they just supply a box and card and let me do the rest?
    Dak
  4. shawkins002
    shawkins002
    Dec 12, 2002
    237
    Epsom, Surrey
    I did the normal sky installation myself, and used a friend's old box. They sent through the card and everything OK - switched on within about 10 days.
    With Sky+ they wouldn't let me do a self installation, and had to send someone round. But I installed the Quad LNB before he got there and ran the second cable through, so all he did when he turned up was plug in the Sky+ box. Which cost me £50. He didn't even look at the dish, so it wasn't a problem. They don't really give a monkeys, and if you've done their job for them, I'm sure they won't care if it's connected to a 60ft coat hanger - as long as the signal strength etc is OK when it's plugged in.
